NTP (Network time protocol)
It would be useful to have the inverter have the option of syncing its time using NTP or SNTP on a time server to keep the time from drifting. Important when handling schedules. Also an option to enable/disable daylight savings depending on meter tariff being aware of daylight savings or not.
1 x H1-5.0-E-G2-WL Inverter with 5kW G99 DNO export approval
1 x EP12 (W) Battery with heater
8 x Eurener 450W PV panels (3.6kW)
EPS sockets using inverter's internal EPS output
Re: NTP (Network time protocol)
I believe it already does it, although when I first had my system the time was drifting (I think Fox's NTP server was unreachable or something). After a while they fixed it and the time on the inverter (KH7, if relevant) has been correct since then.
I did write a crude automation to correct the time myself, twice daily, but ironically that was just before they fixed their NTP server so it was only useful for a few days.
If it does it, there should be an option to configure it somewhere, even if it's just to confirm it's working
