Revenue settings
I think something has changed recently in the app calculations regarding tariffs and therefore revenue.
Since this feature was available I loaded the tariff options with my Octopus rates (in £/kWh). This then showed correctly on the revenue calculations. Recently however, I note that the app is expecting the rates in p/kWh and thus the total revenue is displayed as pence rather than pounds. Currently my total revenue is showing as 761.98 pence rather than the £761.98 that it should.
I have a feeling that it's the tariff module that has changed from £/kWh to p/kWh but it still keeping the original user input figures (or those imported from the electricity supplier.)
I know that this is only a rough indication of income and expenditure, but having the correct unit calculation would be good :)
Cheers
Brian
Re: Revenue settings
I would highly recommend you track the values by a spreadsheet, this will give you better figures overall.
I know it can be a useful guide to have, but it is not good enough (yet)
Let's say you input a cost per kWh at 25p today, over time this value will change in time. Issue is, if the new rate 10 years from now is 50p per kWh, then it back dates ALL the usage to the new rate... so blows you calculations out of the water.
TL;DR
Delete your current TOU Tarrif Plan and create a new one with the appropriate value.
I'm not sure what version of the app you're referring to. I have a freshly installed v2 and made a mistake while setting up the buy tarif. I've put set it in currency instead of cents... I didn't manage to find the very narrow place to select to change the value so I've deleted the tarif and recreated one. I'm now stuck with a bad price (100x compare to reality) for the first two days while I'm fine for the days after.
Thanks both
