Strange vp2 behaviour
Just installed a fox ecs-h1-3.7 hybrid system with 2 strings of 6, 545w panels, it’s been running since January but only just thought to interrogate the individual string performance, and realised that string PV2 has never contributed anything from the start. I checked the power on each string and both are generating all the way up to the PV inputs on the inverter.
I moved the PV2 string over to the PV1 input, and it started to generate. I connected the PV1 string to the PV2 input, and it did not generate.
I checked that the settings for the strings were set to independent, OK
On the inverter during operation the values on PV2 are 8.6v 0.0A and 0w (which would indicate a string wiring fault)
I contacted FOX TECHNICAL talked it through with them, they logged on to the inverter and interrogated it to confirm what I was reporting, and at their request forwarded all relevant readings and full videos of the testing.
FOX agreed that it must be an internal fault on the inverter, and immediately dispatched a replacement inverter, which arrived in 2 days.
I exchanged the inverters, AND HERE IS THE STRANGE THING ! 🤬🤬ITS STILL THE SAME.
Can anyone tell me what I have missed please
Re: Strange vp2 behaviour
Weird!
Did you measure PV2 string voltage with the string connected to the inverter?
Tested in both
Ray
Can you set the PV configuration to parallel instead of independent? This should show the correct amount of power and would use just one MPPT. That's if you are unlucky to have received a replacement that is also faulty.
I am clutching at straws, and there are more experienced solar bods on this forum.
The two strings are on different orientations south and west so they are set to independent.
Can Fox do another remote diagnosis?
After initial testing and inspection. Both fox and I agreed that the inverter was at fault, so fox immediately replaced it. When the replacement was installed the same things were still happening. Given the unlikely scenario that the 2nd inverter was also faulty we conducted all the tests again plus numerous other tests, however looking at the solar arrays and cabling etc but nothing was found that would explain the problem.
The inverter is not showing any error codes just reporting normal operation but the 1st array has now stoped working and the inverter can’t detect it although like the other string it is delivering voltage and current to the inverter dc inputs.
Because the inverter can’t detect the panels it’s not charging the batteries, but it’s allowing the batteries to discharge below the set minimum state of charge (10%) they’re at 5% currently so I have isolated them
To their credit Fox have invested a lot of time in assisting in the location of the problem.
They are of the opinion (and I agree) until proven otherwise, it’s not an inverter problem.
The current situation is I have decided to strip the entire system down and check everything with regards to layout, cables, joints, all individual panels, etc.
Happy days.
Thanks for the update. Please keep us posted on you findings.
Best of luck!
