Modbus Ethernet connection failing in Homeassistant
Hi all,
I am new to this community and so far did not find an answer to my challenges in integrating the HACS Modbus integration.
I have purchased the FOXESS Ethernet Modbus adapter. I have identified the right IP address and configured the Modbus integration. Never the less I get the error
Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 30; slave: 247 from tcp://192.168.1.53:502: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
Is there any advice what I am doing wrong?
Many thanks
Ben
Re: Modbus Ethernet connection failing in Homeassistant
It sounds like you aren't connected to the inverter properly. It could be a configuration or wiring issue. How did you make the connection and what battery/ inverter do you have?
7.36kWp solar array made of 16x Jinko Tiger Neo 460w panels. 8 ESE, 8 WNW facing, Fox EVO 10kWh with 10kW inverter. Installed April 2026. Running ModBus via Elfin EW11A, learning Home Assistant
I just recognized today, that the ethernet comm adapter does not fully support RS485.
