How often to fully cycle EP12 12 batteries?
I have had a pair of EP12 batteries for a month, and am very happy with the install and the performance (batteries only - no solar (charge overnight on IOG & signed up to Axle - events only)).
One thing I'm not sure of however, is, is there a requirement to fully charge & discharge the batteries occasionally?
My max charge is set to 85%, and I can set that to 100%, but I can't see how to set minimum to 0%.
Do I need to cycle, and how to set to 0% if I do please?
Thank you.
Re: How often to fully cycle EP12 12 batteries?
In the UK, you can only set a minimum floor of 10%, max 100%.
Here is a thread regarding charging viewtopic.php?p=12652#p12652
Wyndstryke has posted a reply in 2nd post down that's fairly comprehensive.
Thanks @MaterialBarracuda48
So I'll forget about the 0% then.
Regarding the 100% weekly charge recommmded, is that what most users are doing? It's a pity the scheduler doesn't have a weekly option to automate this if so.
Thanks again. :-)
I was on IOG, so mine would hit 100% each night... but the trick was for me, was to discharge a little after the off-peak rate finished. I discharged for 1hr from 05:30 to 06:30 on a single EP11, the SoC dropped to 55~60% SoC.
The system also seems to charge the battery in a trickle (maybe a firmware bug) so the SoC would creep up by around 1% for me every 30mins on an average :D
Will has many excellent videos on youtube to look at https://www.youtube.com/@iameccles/videos
This one in particular should be a good starter
Thanks again 😊
I'll take a look at the YouTube videos over the weekend 👍
