I own a configuration made of 6 battery module 1.5kw each, total should be 15kw.
From the application battery detail section, I read instead 12.5kw , someone can help me debug this issue?
I don't have quite the same system as you as I have a type C stack with v1 BMS. Though I am under the impression that the dip switch on the BMS needs to be set correctly depending on the number of modules you have. Looking a your image it is set to 0. Which is equal to the 2 batteries i think it should be set to 4.
