FoxESS H3 — Load Overpower Fault
Hi everyone, I’m having an issue with a FoxESS H3 showing Load Overpower Fault.
The system is currently showing this fault and I’d like to know what could be causing it and what I should check first.
Has anyone experienced this before, and what was the fix?
Thanks in advance!
Re: FoxESS H3 — Load Overpower Fault
Might be an idea to fetch the error code value(s)
If you cannot get them from the various screen/App, then you are going to have to let it fault again to retrieve.
