Good morning All,
I've recently had a fox Ess 10kw battery fitted along with solar panels.
Im on octopus so I set up the mode scheduler for forced charge between 2330 and 0530. When I checked early in morning battery full as expected.
When I plug in my EV via an Ohme Epod, the battery is drained into the car and the mode has changed to self use. I cant see what to change so car and battery charge simultaneously.
Any help much appreciated
Alastair
Have a read here, then post questions if you have some afterwards.
viewtopic.php?p=16688#p16688
