Foxcloud 2.0 latest release Meter compensation bug
The sliding bar to set the amount positive or negative adjustment seems to be reversed in latest update. Previously moving the circle left gave a negative value ie -25 while moving it right gave a positive value ie 25. In this latest Foxcloud app update this is now reversed from previous versions.
I also have noticed that I’m exporting higher amounts of solar power vs previously by quite large amount when recharging batteries after charging EV! Never had this issue until this latest app update!
22 465w Solar Panels
FoxESS KH8 Inverter
FoxESS 3 off EP12 Batteries
Hypervolt Home 3 Charger
Grant Aerona 290 9KW ASHP
OVO 20p SEG
Re: Foxcloud 2.0 latest release Meter compensation bug
I have seen the same since I posted about this viewtopic.php?p=17996#p17996
Can you show with pictures?
