Correct way to restart the inverter
I'm in bit of a confusion on the correct steps to restart fox ess H3 10 inverter. I have 15.6KW solar and EQ4800 battery. My installer has stuck the procedure as per the attached photo which says to turn off AC isolator first but as per the video I've watched in YouTube on iameccles channel it says:
1. Turn off DC isolator
2. AC isolator
3. Turn off battery
I'd really appreciate some expert advice here. I've had to do the reset twice already so wanna make sure I'm doing it right. Also, my apology if it's been discussed already here in the forum coz my quick search didn't bring any results relating to it. Thank you.
Re: Correct way to restart the inverter
Here is a video from Will
If you still have extra questions, post back.
MaterialBarracuda48 wrote: ↑Thu Oct 01, 2026 11:04 am Here is a video from Will
Thanks ya that's the exact video I'm referring to in my initial post. So, that is the correct way and the sticker my installer stuck on my inverter is incorrect? Coz I've been following that video and turning off DC isolator in my inverter first, then the AC isolator and then the battery.
I have been AFK for a while, but taken from my set of instructions left
4. Switch the DC Isolators at the Inverter to OFF
Step 5. is missing on mine, but the battery is turned off
Reverse for power on cycle.
