Can anyone explain why my house is showing a net export?
I have 2 inverters. Looking at the Fox Cloud app, it occasionally shows the house exporting electricity!
By way of example, yesterday the dashboard was showing:
Solar: 3.27 kW
Total Home: -2.31kW
Grid 5.63kW
Granted that there will be some rounding errors in these figures depending on timing of readings from inverters and SMETS meter. But the house is still consuming power!
Any thoughts please?
Many thanks.
Kind regards,
Matt
Re: Can anyone explain why my house is showing a net export?
make sure the time is set correctly on both the inverters.
with the 5 min updates, the data can look very odd at times due to the how the freeze frame data works.
If you really want accurate data you could use home assistant or install a shelly EM device to get second by second export data on your phone.
Thanks Will,
Will double check the times on each inverter.
Forgive my ignorance but what is a shelly EM device?
Cheers,
Matt
