I have just discovered my batteries have different version number, please see screen dump attached.
Should i ask the installer to update or is this nothing to worry about?
Battery serial numbers
At a minimum all the slaves should be the same version, but actually they are really old firmware versions, I would recommend you ask your installer or raise a ticket along with your inverter serial number to FoxESS and get them updated - later versions have improved capacity, temperature handling and SoC stability.
Current Mira Versions are :-
1.011 for Master (BCU) and 1.09 for Slave (BMU)
