Switched to 2.5ghz WiFi - broke Energy Stats?
lms10000
Hi. I temporarily deactivated 5ghz WiFi so I could set up some smart bulbs. When I switched back to 5ghz I was logged out of energy stats - and I can’t get back in.
I’ve tried copying the API key from Fox ESS about 6 times - just as when I first set it up - but just get the ‘could
Not log in message’ every time. The Fox app also logged
me out but I was able to log back in.
The switching bandwidth thing might be irrelevant, but is seems odd that I was kicked out at the same time.
Any advice greatly appreciated!
It’s nothing you’ve done - the Fox OpenAPI is down completely at the moment for all users - probably best to leave it til tomorrow morning and hopefully it’ll be back up again.
lms10000
Ah I see! Thanks so much Dave - should have checked that first.
It came back approx 2.25am, all working normally now - so you're good to go.
lms10000
Brilliant - I’m back in. Thanks again!
