Hello ... I did a few versions of software updates today and sensor.foxess_eps_rpower is not working correctly. It works when I'm in self-use mode but when pulling from the grid it drops to zero. Meanwhile sensor.foxess_eps_rcurrent is still working fine (showing 14.7A for example when eps power shows 0 kW.
My whole house load is on EPS output, so that's why I use this number a lot.
Can you pass that along to the Fox folks and get it fixed?
KH 10.5
24 x 480w PV panels N/S
8x ECS4800v2
W4 Datalogger
Home Assistant via Modbus
Sussex
8x ECS4800v2
W4 Datalogger
Sussex
Will is aware of this one, it seems to occur when you are running the EPS in UPS mode - he has reported it to Fox (last week), when he next checks in hopefully he can updateUK_KH_User123 wrote: ↑Wed Feb 12, 2025 11:45 pm Hello ... I did a few versions of software updates today and sensor.foxess_eps_rpower is not working correctly. It works when I'm in self-use mode but when pulling from the grid it drops to zero. Meanwhile sensor.foxess_eps_rcurrent is still working fine (showing 14.7A for example when eps power shows 0 kW.
Thanks Dave! Yes, that's how I run it too. Not a big deal. Using "load_power" instead may give the same numbers in my use case anyway.
KH 10.5
8x ECS4800v2
W4 Datalogger
Sussex
8x ECS4800v2
W4 Datalogger
Sussex
