changing export to gid value
Hi, can anyone tell me how to change the export limit using the front panel on my KH10.5? I thought i had found the setting. Its set at 1300w but i regularly see much more than that going to grid, so probably not the right setting! I cant sell to grid so i thought it best to limit the export to 3.68. Which is the value i believe to keep it to g98 and make the DNO application a lot simpler. Thank you.
Re: changing export to gid value
Grid export setting is adjusted as per my video:
Remember, you can't use the fox app to tell what you're exporting realtime as the app only updates every 5 mins it can look like you're exporting more but you're not as the inverter has to respond and change the output every second or so.
If you have an in home monitor or octopus mini these are a reliable way to monitor your export or the historical graphs in the fox app.
You might still have an issue with a G98 application with a 10.5kW inverter. The effort isn't much more to apply for a proper G99 and get a proper export allowance.
2 x KH & 1 x H1
Darn. Forgot about your youtube site, Will. Trying to find an installer to take over my installation. No mcs or dno atm. It was done at the height of the nonsense, 2021 or 2022, the installers disappeared before they finished it. So i had to finish it myself. Think i have found a local company willing to do it. G99 is way too complicated for me to fill in! Just watched your vid. So easy when you know how! :D Thanks Will.
No other company will be able to issue an MCS cert sadly so you will need to go down the self certification route with octopus to get export payment working. I offer a remote service to take care of your system and be there for any future updates or warranty claims. I can for a fee also help you with the G98.
If you're interested in the remote service let me know.
2 x KH & 1 x H1
