I am on Octopus IOG for import and the flat 15p export rate.
My inverter is a Fox ESS H1 SERIES (G2) 5kW Hybrid Inverter.
My battery is a Fox EP11 10 kWh battery with a 90% depth of discharge
What I want to do in English is ...
- Charge the battery between 23:30 and 05:30, and not use the battery should I also charge the car.
- Feed in all my surplus between 05:30 to 18:00.
- From 18:00 to 19:00 I want to discharge to the grid leaving 50% for the evening.
- Then from 22:00 I want to dump any remaining battery to the grid but leaving 12%. I've set the minimum to 12% as I noticed it went below 10% when set at 10.
00:00-05:30 - Force Charge: Min SoC 10%; Max SoC 100%; FD SoC 10%; FD Pwr 0W
05:30-18:00 - Feed In: Min SoC 10%; Max SoC 10%; FD SoC 10%; FD Pwr 0W
18:00-19:00 - Force Discharge: Min SoC 10%; Max SoC 50%; FD SoC 50%; FD Pwr 5000W
19:00-22:00 - Self Use: Min SoC 10%; Max SoC 100%; FD SoC 10%; FD Pwr 0W
22:00-23:30 - Force Discharge: Min SoC 10%; Max SoC 10%; FD SoC 12%; FD Pwr 5000W
23:30-23:59 - Force Charge: Min SoC 10%; Max SoC 100%; FD SoC 10%; FD Pwr 0W
Is what I've input into the app correct? Would you consider this overkill?
Many thanks in advance.
Best regards
Andy
