Just curious- EVO10 H How does it drain water?
So, as the title says I'm very curious how the EVO drains water.
Its IP66 rated, so ok for outside and mine is on the front of my house. Its just rained very hard and it got me thinking, if water gets in the vents at the top, where does it exit? there don't seem to be any specific drainage points that I can see?
Thaks
7.34kWh solar array made of 16x Jinko Tiger Neo 460w panels. 8 ESE, 8 WNW facing, Fox EVO 10kWh with 10kW inverter. Installed April 2026. Running ModBus via Elfin EW11A, learning Home Assistant
