App Update now No Quick Settings access
Mobile App updated overnight from 2.2.19 to 2.2.21. Now I can't access any of the "Quick Settings". Spinning wheel, then timeout error. I un-installed and re-intalled of course, to no avail. As for Devices, the battery says Sleep, in the upper LH corner, but the Home graphic shows charging ( noon here). Sys Min SOC and Back up cut off SOC locked at "0" %. Inverter Firmware still not updated by my Installer or Fox( new system, ancient firmware lol). Is this post app update behaviour typical ?
Re: App Update now No Quick Settings access
No that’s not normal behaviour, i’m on iOs with latest app and all looks fine.
It sounds like you don’t have the ability to access your system which is usually a wifi / data logger issue but could be the manager on your inverter that has locked up. Probably best to start with the easiest thing and restart your home router / wifi, wait 5 mins and see if the data is being updated correctly in the app. If not, you’d be best to try a shut down/restart of the inverter / battery system.
According to Grok : Bottom line: You are many major revisions behind. This is not “slightly old” — it is firmware that is functionally obsolete relative to the app and features marketed in 2026.
“Your H1-11.4-US is running Master 1.2 / Manager 1.17 / Slave 1.02 / AFCI 1.02. This is far below current production firmware for a system installed 5 August 2026. Please push the latest available US H1-11.4-US Master, Manager, Slave and AFCI packages immediately. Current firmware is causing battery ‘Sleep’ status, Quick Settings timeouts, and complete lack of Mode Scheduler / timed Force Charge functionality.”
Alas...
