Foxesscloud.com
Might just have been coincidence! It’s the web version of the app. Similar functionality but generally more stable.
Foxesscloud.com
Not a coincidence! I tried the app at about 21:00, which was forlornly reporting that the last update was 8 hours ago. No real-time data anywhere but strangely I could display the complete activity profile from today, suggesting that data had been flowing successfully into the cloud but something was preventing it from being retrieved. I then logged into the web v2 page and found real-time updates! I don't allow dual login so this forced a login back on the app … which now also has real-time data flowing once more. It also seemed to have remembered the schedule updates that I had sent blind earlier today.DIWUK wrote: ↑Wed Mar 11, 2026 8:46 pmFoxesscloud.com
Same here. I guess 5SR will be back when the fully fix the issue.MaterialBarracuda48 wrote: ↑Wed Mar 11, 2026 10:14 pm It has came back to me a while back also, main difference is the 5 second data refresh is not working.
Back to the 5 minute or so refresh speed for now.
What I meant was that nothing was being reported in terms of data. I can seemingly check my Mode Schedule, but it's not seeing the active flow of energy still.
There is a modbus TCP option, but I can't figure out if my inverter doesn't support it, or Fox won't let it be enabled.
Since there seems to be a bug in the app telling data loggers your WiFi details you may need to connect to the data logger another way.
Thanks.Fl1ntst0ne wrote: ↑Thu Mar 12, 2026 8:57 am I believe if your inverter ends with '-WL' then you can use the modbus TCP option. It works for me![]()
The 5s refresh did come back after an hour or so, happy days.DrewXBL03 wrote: ↑Wed Mar 11, 2026 10:38 pmSame here. I guess 5SR will be back when the fully fix the issue.MaterialBarracuda48 wrote: ↑Wed Mar 11, 2026 10:14 pm It has came back to me a while back also, main difference is the 5 second data refresh is not working.
Edit: I now have 5SR back
Yes I had patchy data arriving in, stopped around 17:xx then jumped to 19:xx.london2000 wrote: ↑Thu Mar 12, 2026 7:45 am My system is still offline, having gone offline around 12:45 yesterday. But, weirdly, when I looked late last night, the Energy Analysis chart had updated and was showing Supply and Usage readings up to 17:34. So it seems that it must have come back online for a short time to allow some data to be transferred.
Has anyone else experienced this?
