Using Home Assistant to control house battery and EV battery charging with octopus intelligent go
Using Home Assistant to control house battery and EV battery charging with octopus intelligent go to prevent discharge of battery into the car.
Re: Using Home Assistant to control house battery and EV battery charging with octopus intelligent go
Thanks Will - excellent automation - solves a lot of problems!
I have an H1 inverter - so if you set the Minimum SoC it doesn't charge the battery at all (but does stop discharge) - so below is the code / automation I use to change the working mode.
Notes:
  • When setting up, I created a blank automation, then used the 'id' for that and replaced the generated code with that below.
  • Also the notification is just so I could check it works reliably, will probably remove those after a few weeks
  • Replace the XXX with your entity / meter number
  • Is based on 7p / 25p import rates, at the point of creating this - can adjust according to need
  • This code goes into automations.yaml file - but be careful with any edits!
Enjoy... it may take some time to get the code working... but using ChatGPT can help a lot!
- id: '1738061409369'
  alias: Set Inverter Mode based on electricity prices
  description: ''
  triggers:
  - entity_id: sensor.octopus_energy_electricity_XXX_current_rate
    trigger: state #this trigger happens whenever the electricity price is updated
  conditions: []
  actions:
  - if:
    - condition: template
      value_template: '{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
        | float > 0.20 }}' #checks if the current price is >£0.20 - adjust as needed
    then:
    - data:
        message: Trigger above 15p. Price is £{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
        title: Rate change
      action: notify.mobile_app_pixel_6 #sends notification to my phone when change has been made
    - target:
        entity_id: select.work_mode
      data:
        option: Self Use
      action: select.select_option
    else:
    - data:
        message: Trigger below 15p. Price is £{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
        title: Rate change
    - target:
      data:
        option: Force Charge
  mode: single
Will wrote: Tue Jan 14, 2025 9:11 pm Using Home Assistant to control house battery and EV battery charging with octopus intelligent go to prevent discharge of battery into the car.
Thanks, Will, for all your videos and advice. I’ve recently joined IGO and have fallen into the battery draining scenario! I’ve been manually setting slots in mode scheduler to match the Octopus additional slots, to force charge my Fox ESS batteries, which works fine until these change 2 minutes before the schedule is due to start! I’ve ordered a Home Assistant Green tonight and will be scouring posts for details how to link to inverter and set up software using my iPad… I realise I’m a complete novice at the detailed technical stuff! If anyone has a “Set Up for Dummies Guide”, that would be very helpful! Paul
FoxESS Installation
H1-6.0-E hybrid inverter
7 x ECS4100-2 v1.13. 28.2 kWh
18 x 390w panels across 2 arrays
1 x EV
1 x Heatpump
paulbw32 wrote: Sun Dec 14, 2025 10:14 pm I’ve ordered a Home Assistant Green tonight and will be scouring posts for details how to link to inverter and set up software using my iPad… I realise I’m a complete novice at the detailed technical stuff! If anyone has a “Set Up for Dummies Guide”, that would be very helpful! Paul
I have recently setup HA Green, so it is still fresh in my mind, I recommend you create a post in the right section to get help.
viewforum.php?f=5
I can give you a few pointers over there Paul if you make a thread.
Hello Will,
I was going to buy the HA Green and try to use it to control my Ohme charger to charge only after 11:30pm to avoid the battery discharging but not sure if this is possible. (I am assuming that Octopus would adapt its low tariff slots to suit.)
I can see that it is possible for me to follow your idea of controlling my FoxESS battery instead, but Octopus has recently decided to have the low tariff EV charging slots independant of the low tariff house slots; as I understand it. So wouldn't that have the disadvantage, that if power was needed in the house (like the cooker), at the time of the low EV charging tariff, it might import high tariff house energy to power it?
Interested to have your thoughts on this.
John
CrabbyHorse wrote: Fri Apr 03, 2026 8:01 pm Hello Will,
John
A few things to clarify, IOG takes care of your system, if you try to take 'control' of charging, then you will likely get kicked off the tariff at some point. They are clamping down on things, just a matter of time before it happens.
With Will's solution, that I have implemented on my HA Green, it simply listens for the 'off-peak electricity' flag to be turned on, which should happen during the overnight period OR if you get a random slot assigned outside of the fixed off-peak times. It works fine with my Zappi, I do not control it at all. I am not sure what integration there is with the Ohme within the HAOS, but there could be some 'flags' there to capture when it is commanded to start.
The low power slots have always been independant of the fixed overnight slots, only real change is you are only allowed 6hrs of charging time per 24hrs (an Octopus day starts at 12pm) typically overnight is cheap power, so majority of the slots allocated are set to overnight. If the grid has surplus in the evening, and it benefits Octopus in your area, they could charge your car for 30mins or more to balance the grid.
If the car is charging via Octopus IOG, then your home (cooker/battery/whatever) will be at the cheap rate. The only exception is if you choose to 'bump' charge and then it is at peak rate.
Hello again.
I have bought a Home Assistant Green, but am struggling to start because it doesn’t seem to recognise the Fox Battery as a device. It sees my router and printer and other ‘devices’ that I don’t recognise. There is only one router here. What do I need to do to program the FoxESS ?
John
CrabbyHorse wrote: Thu Apr 09, 2026 3:33 pm Hello again.
John
Have you made any progress with this?
Can you state what you have done so far (installed this/configured etc)
I have installed HA Green and viewed the devices: Here are the attributes of my printer for example, but how do I discover and link my IOG energy account and my fox battery?
John
Let's sort one issue then at a time,
First thing is to get your Octopus account seen by HA, this needs Bottlecap Dave adding, but before you even add that you need ideally HACS (think of this as a custom add-on store) loading.
1. Install HACS
2. https://github.com/BottlecapDave/HomeAs ... pus-energy
Once you have this working, then we can cross the next bridge, ask if you get stuck along the way
I never thought this was going to be so difficult!
I added HACS after a lot of head-scratching (the 'my link' wasn't there to click on).
I have got this far with adding Octopus - with an update outstanding .
Am I right so far? What happens now?
John
If you have not yet setup your Octopus integration, then you need to click this, you will probably need your Octopus Api key and account number (been a whiile)
https://my.home-assistant.io/redirect/c ... pus_energy
Let me know if you have already done this setup already.
No, but I have done it now.
No idea what most of the settings mean but I have completed it.
What happens now? How do I set up the Fox side of it?
Thanks so far.
John
CrabbyHorse wrote: Fri Apr 17, 2026 8:59 am No, but I have done it now.
Thanks so far.
John
Hello John,
So to talk to your Inverter, we need to have some hardware in the middle of it all. This does depend on what Inverter you have, as some have modbus via WiFi ability.
I have one of these for the hardware between the HA Green and my Inverter.
https://github.com/nathanmarlor/foxess_ ... 85-%28B%29
So what Inverter do you have, you might be a lucky one with built in communications.
