Using Home Assistant to control house battery and EV battery charging with octopus intelligent go to prevent discharge of battery into the car.
Thanks Will - excellent automation - solves a lot of problems!
I have an H1 inverter - so if you set the Minimum SoC it doesn't charge the battery at all (but does stop discharge) - so below is the code / automation I use to change the working mode.
Notes:
Enjoy... it may take some time to get the code working... but using ChatGPT can help a lot!
Notes:
- When setting up, I created a blank automation, then used the 'id' for that and replaced the generated code with that below.
- Also the notification is just so I could check it works reliably, will probably remove those after a few weeks
- Replace the XXX with your entity / meter number
- Is based on 7p / 25p import rates, at the point of creating this - can adjust according to need
- This code goes into automations.yaml file - but be careful with any edits!
- id: '1738061409369'
alias: Set Inverter Mode based on electricity prices
description: ''
triggers:
- entity_id: sensor.octopus_energy_electricity_XXX_current_rate
trigger: state #this trigger happens whenever the electricity price is updated
conditions: []
actions:
- if:
- condition: template
value_template: '{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
| float > 0.20 }}' #checks if the current price is >£0.20 - adjust as needed
then:
- data:
message: Trigger above 15p. Price is £{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
title: Rate change
action: notify.mobile_app_pixel_6 #sends notification to my phone when change has been made
- target:
entity_id: select.work_mode
data:
option: Self Use
action: select.select_option
else:
- data:
message: Trigger below 15p. Price is £{{ states("sensor.octopus_energy_electricity_XXX_current_rate")
title: Rate change
- target:
data:
option: Force Charge
mode: single
Thanks, Will, for all your videos and advice. I’ve recently joined IGO and have fallen into the battery draining scenario! I’ve been manually setting slots in mode scheduler to match the Octopus additional slots, to force charge my Fox ESS batteries, which works fine until these change 2 minutes before the schedule is due to start! I’ve ordered a Home Assistant Green tonight and will be scouring posts for details how to link to inverter and set up software using my iPad… I realise I’m a complete novice at the detailed technical stuff! If anyone has a “Set Up for Dummies Guide”, that would be very helpful! Paul
FoxESS Installation
H1-6.0-E hybrid inverter
7 x ECS4100-2 v1.13. 28.2 kWh
18 x 390w panels across 2 arrays
1 x EV
1 x Heatpump
1 x EV
1 x Heatpump
I have recently setup HA Green, so it is still fresh in my mind, I recommend you create a post in the right section to get help.paulbw32 wrote: ↑Sun Dec 14, 2025 10:14 pm I’ve ordered a Home Assistant Green tonight and will be scouring posts for details how to link to inverter and set up software using my iPad… I realise I’m a complete novice at the detailed technical stuff! If anyone has a “Set Up for Dummies Guide”, that would be very helpful! Paul
viewforum.php?f=5
I can give you a few pointers over there Paul if you make a thread.
Hello Will,
I was going to buy the HA Green and try to use it to control my Ohme charger to charge only after 11:30pm to avoid the battery discharging but not sure if this is possible. (I am assuming that Octopus would adapt its low tariff slots to suit.)
I can see that it is possible for me to follow your idea of controlling my FoxESS battery instead, but Octopus has recently decided to have the low tariff EV charging slots independant of the low tariff house slots; as I understand it. So wouldn't that have the disadvantage, that if power was needed in the house (like the cooker), at the time of the low EV charging tariff, it might import high tariff house energy to power it?
Interested to have your thoughts on this.
John
John
A few things to clarify, IOG takes care of your system, if you try to take 'control' of charging, then you will likely get kicked off the tariff at some point. They are clamping down on things, just a matter of time before it happens.CrabbyHorse wrote: ↑Fri Apr 03, 2026 8:01 pm Hello Will,
John
With Will's solution, that I have implemented on my HA Green, it simply listens for the 'off-peak electricity' flag to be turned on, which should happen during the overnight period OR if you get a random slot assigned outside of the fixed off-peak times. It works fine with my Zappi, I do not control it at all. I am not sure what integration there is with the Ohme within the HAOS, but there could be some 'flags' there to capture when it is commanded to start.
The low power slots have always been independant of the fixed overnight slots, only real change is you are only allowed 6hrs of charging time per 24hrs (an Octopus day starts at 12pm) typically overnight is cheap power, so majority of the slots allocated are set to overnight. If the grid has surplus in the evening, and it benefits Octopus in your area, they could charge your car for 30mins or more to balance the grid.
If the car is charging via Octopus IOG, then your home (cooker/battery/whatever) will be at the cheap rate. The only exception is if you choose to 'bump' charge and then it is at peak rate.
Hello again.
I have bought a Home Assistant Green, but am struggling to start because it doesn’t seem to recognise the Fox Battery as a device. It sees my router and printer and other ‘devices’ that I don’t recognise. There is only one router here. What do I need to do to program the FoxESS ?
John
John
Have you made any progress with this?CrabbyHorse wrote: ↑Thu Apr 09, 2026 3:33 pm Hello again.
John
Can you state what you have done so far (installed this/configured etc)
I have installed HA Green and viewed the devices: Here are the attributes of my printer for example, but how do I discover and link my IOG energy account and my fox battery?
John
John
Let's sort one issue then at a time,
First thing is to get your Octopus account seen by HA, this needs Bottlecap Dave adding, but before you even add that you need ideally HACS (think of this as a custom add-on store) loading.
1. Install HACS
2. https://github.com/BottlecapDave/HomeAs ... pus-energy
Once you have this working, then we can cross the next bridge, ask if you get stuck along the way
1. Install HACS
I never thought this was going to be so difficult!
I added HACS after a lot of head-scratching (the 'my link' wasn't there to click on).
I have got this far with adding Octopus - with an update outstanding . Am I right so far? What happens now?
John
John
If you have not yet setup your Octopus integration, then you need to click this, you will probably need your Octopus Api key and account number (been a whiile)
https://my.home-assistant.io/redirect/c ... pus_energy
Let me know if you have already done this setup already.
No, but I have done it now.
No idea what most of the settings mean but I have completed it.
What happens now? How do I set up the Fox side of it?
Thanks so far.
John
Thanks so far.
John
Hello John,CrabbyHorse wrote: ↑Fri Apr 17, 2026 8:59 am No, but I have done it now.
Thanks so far.
John
So to talk to your Inverter, we need to have some hardware in the middle of it all. This does depend on what Inverter you have, as some have modbus via WiFi ability.
I have one of these for the hardware between the HA Green and my Inverter.
https://github.com/nathanmarlor/foxess_ ... 85-%28B%29
So what Inverter do you have, you might be a lucky one with built in communications.
Here is the rating plate:
And the info from the App :
So it has a data logger if that is what is needed?
Thanks again.
John
Thanks again.
John
So John,
Now is where you have to get your hands dirty, you are going to need to wire up a hardware interface between inverter and your HA Green.
As you can see above thread, I showed you that I use a USB Waveshare device to take the modbus signal from the inverter and feed this into the HA Green.
https://github.com/nathanmarlor/foxess_ ... d-Versions
On the right hand side of this page, you can see a list of hardware that can "bridge" the connection between Inverter and HA Green. What you choose will depend on what you have available near your Inverter. I have a LAN connection for my HA Green, and the USB waveshare device is close enough to reach both.
Wiring guide and what pins to use, will depend on your connection
https://github.com/nathanmarlor/foxess_ ... ring-Guide
OMG !!
I don't think I would have started this project if I knew all this. All I want to do is to eliminate setting my alarm clock to 11:30pm when the EV is plugged in!
I think I would need to get my battery installer to quote for doing this. Probably prohibitive.
John
John
If you have this square style connector, then they are not that hard to DIY.
viewtopic.php?p=7586#p7586
Unless you are awful with DIY, you are close to getting this finished. It is definitely daunting for a first time, but not impossible.
I have taken some photos of the inverter connections and one of the battery connections.
I'm none the wiser; nothing obvious that looks like that square connector.
John
John
3rd picture John,
Meter / CT / RS485 There are some pressure points you push in on both sides (depending on how you look at it) and you can then pull it out.
Before you play tug-o-war, you have to power down the Inverter/battery to do this.
How close this is going to be to your HA Green is another consideration, as you need to feed a cable between the two items.
There are two big problems;
1. Following the cables from the battery (housed outside), I would need to move the HAG to the electrics cupboard under the stairs where there is no socket.
2. The cable enters the house behind either the inverter or battery so I would have to lift it/them off their mountings.
So I'm not yet sure if the hole is big enough for another cable.
What sort of cable is needed? Something like an ethernet cable?
I still think I'm going to need an electrician. I'm comfortable extending a ring main with a new socket but not directly off the consumer unit. And it would take two strong men to lift the battery off the wall to expose the hole in the wall.
John
John
The cable that goes from the Meter / CT / RS485 will enter your house and head towards your electric cupboard, where you should find a CT Clamp.CrabbyHorse wrote: ↑Sat Apr 18, 2026 10:58 am There are two big problems;
John
If you are very lucky, this cable is more than likely going to be a ethernet cable. If you check in your meter cupboard, you might be able to find the CT Clamp wrapped around the mains after the meter. Carefully take a look at the cable feeding the CT Clamp to see if there are some spare wires in the cable.
Depending on what you find at the meter end of the cable, you might just be able to utilise an unused pair for the RS485 connection.
Have a little dig about and let us know what you find.
You might not need to lift the battery off the wall or muck about like that.
Sorry for the delay.
I have just looked in the cupboard under the stairs and have taken these three photos.
There are three cables coming in from the the external inverter/battery. One powers the emergency socket for when there is a power outage, and the other two go into the bottom of the solar panel consumer unit.
Another small black cable comes out of the same unit (don't remember if it was there beforehand), which goes to a clamp on the the main red solar cable. There are two other clamps on the same cable; one (white) to the iBoost water heater (obsolete now) and another (black) that goes into the small grey Wagobox. I don't know what it's for.
Any ideas? It doesn't look very promising to me!
John
John
Hi John,
In your 3rd picture, it looks like the network cable (it looks like one) enters the 2nd port on the CU from your Inverter.
This then exits to a CT clamp of course.
Now the problem is, that you are going to have to open that CU and find the network cable, and that's Tiger territory, so not recommended.
There might be a way to control the system via HA still, user nicois has created an addon that you might be able to make work, and could be safest choice for you. I think you should take a look here, and ask directly if their integration can work for you?
viewtopic.php?p=15707#p15707
