EV Charger A series, C series L series which one is the latest?
Hi All,
Does anyone know which series EV charger is the latest/best?
I have a Fox ESS Battery and now need a charger and would like it in the same app (FoxCloud 2.0) so looking at Fox chargers.
Also does anyone have a list of Australian sellers as I can only find like 2 in the whole country.
Thanks in the bank!! :D
P.S we have had our Fox battery for almost 2 month as we are supper happy with it.
It never goes below 75% and the power company is always in the red. Bills < zero.
Re: EV Charger A series, C series L series which one is the latest?
Hey Josh, any update on this?
I've got the kh10 inverter and I'm thinking the a series is the go to, but I'm having trouble finding how it can connect.
Hi Mike,
I was told by a supplier here the 'L' Series is the newer one.
Beside the detachable cable option it has everything the 'A' series has.
One thing the 'L' has is the cables going to the power box can go straight into the back which the A can't
Nobody got back to me on here but maybe this will start a thread on it.
I've attached the data sheet for the 'L' and the 'A'
As for the inverter Mike, the chargers don't have any connection with them, it's own circuit it the switch board.
The way they interact is via the FoxCloud2.0 APP so you can set different triggers for stuff.
Anyway hope that helps
FoxESS A7300P1 Datasheet.pdf
(604.62 KiB) Downloaded 37 times
FoxESS L011 Datasheet.pdf
(557.45 KiB) Downloaded 33 times
Thanks for that Josh.
Yeah it's a shame the info is so hard to come by.
I'm looking at an A series, but I'm slightly concerned that if the only comms is via the app and cloud, then it will react really slowly to PV linkage and changes in PV output etc.
Another thread I've got going says comms can go to the inverter. I'll try and find more info.
Hi Josh et al - Following your progress with great interest because I also have a Fox battery (41.93kWh) & inverter (15kW)
There is also the C series EV charger which I understand has TWO EV charging ports - perfect for a 2 EV car household.
Hi Mike,
I could be wrong here but I think the PV stuff gets triggered directly from the meter (over rs485)
Is that what you mean, when there is extra solar being produced put it in the car?
I think the app is just for changing setting and displaying data.
Good point though if it has to wait for the app to update with its current situation then trigger a reaction.
Let me know what you find, id be very interested if there is a bottle neck I should be addressing.
Hi Gino, Yeah super happy with the big battery hey, mine hasn't been below 78% yet :D . Ok so that's what the C series is a duel charger, definitely would be the go if you had two car spots. I can't find any info on it here in Aust
My install is booked for two weeks away L series, I will let you guys know how it goes (Hopefully the car will arrive at the same time :roll: )
awesome - how exciting a charger AND an EV :D Super keen to hear how it pans out. Yeh I've been cycling my 42kWh battery every day and achieving monthly credits through Flow Power
