Batteries not charging or discharging
andyarcher
My batteries are stuck on mid 40% charge and won’t charge or discharge. I was producing 5kw extra and rather than charging the batteries it was going straight to the grid. For 3 days they haven’t discharged either. I know the temp can have effect but it’s not that cold it’s 3degrees centigrade.
First question are there any errors at all ?
Second question do you have any schedules or charge periods set - if you have no charge periods in use they should be set to 00:00-00:00 and charge from grid switched off.
Third question, what is your minsoc and minsoc on grid set to ?
I know you said it’s not cold it’s 3C but the batteries will reduce charge current below 15C, and will no longer charge at all at 0C - they will discharge below 0C but again will be severely limited.
andyarcher
1) I have no error message
2) charge period is get to 00:00-00:00 and charge from grid switched off
3) minsoc 10% and minsoc 10%
Not sure what I can do maybe turn it off and on?
calum
It's because they're cold. When it warms up, you should see them come back to life.
FoxESS Modbus HA Integration
Contact Fox here
