See the real power of the panels production
Good evening,
I have a photovoltaic system with 6 525 W panels and a FoxESS H1-3.0-E inverter installed, but no batteries.
At the moment, the application does not display the total production of the panels, but only the value according to what I consume.
My question is the following:
- Is it possible to check in the FoxESS application what the panels are actually producing in total?
- In the inverter, what are the necessary settings to be able to display the power actually produced?
I thank you in advance for any help you can provide.
Re: See the real power of the panels production
Are you using the V2 app? - that will show you on the first page Today PV Yield - which the PV production for your site.
In the V2 app, you can then select Device, Inverter, Detailed Parameters - under PV that will show the PV performance for each string 'now' and the Analysis graph will show you the PV production for day, month, year etc..
Note that the power consumed is equal to what the panel is producing.
It's a beautiful sunny day and the panel should be showing the maximum power produced.
I'm attaching an example of a HUAWEI inverter, installed in a family home, where it shows the real power of the panels.
That's how I wanted it to appear on mine.
Is it possible?
So lots of questions,
is the Fox inverter fitted with a CT clamp (or meter) and is that attached on the feed from your grid meter ? and is the Meter/CT enabled in the inverter settings ? - this is essential for correct operation of the inverter
Do you have an export limit set in the inverter settings (it appears so as this would restrict PV to load)
Just to confirm it looks as if you have no battery fitted.
Thank you for your cooperation.
The inverter has a meter and is enabled as "CT".
The export limit is set to 00000.
I don't have batteries installed.
Now, another question.
I tried to change the 10 minute average grid voltage to 254 V, but the message "Fail" appears and does not make this change.
What is the solution to this problem?
As you have set an export power of 0 the inverter will only ever output at the same power as the load - without a battery or export there is nowhere for the extra power to go - the inverter cannot generate power unless it has a consumer for it.
Set the 10 minute average voltage in the inverter settings, but if the alarm has been disabled by an installer it cannot be set.
Thanks for the help.
