Yes, I get it. Thanks.
So I use Mode scheduler now instead? I can not see anywhere my current off peak charging though that was expecting to see (and disable). My battery currently charges at 3am for one hour and I want to stop this.
I'm in the UK, on the Fox cloud 2 app we can click on the "work mode" icon to call up " mode scheduler"
On this mode we can enter
Self use
Feed in priority
Back up
Forced Charge
Forced Discharge
So you can charge for various times, discharge when you want by putting in what time settings you need.
Can you download the Europe issue of the App, could this help?
Self use
Feed in priority
Back up
Forced Charge
Forced Discharge
I had the same problem when he app changed last month.
I have the off peak times set up for battery charging and just toggled it on or off when i needed to. That function disappeared from he app so the workaround was to use the desktop version (which briefly worked), but now I can not see the time slot I had set up now in the desktop (but is still charging in off peak), I now want toggle off.
This is all I've used the app for, or probably ever will, its over complicated for me and now doesn't seem to do what I want (or maybe it does but its buried in all the other functions).
Hi, I've set up a different time slot in the work scheduler part of the app. I'wills see tomorrow if that overwrites the one that has currently been operating I set before the change. Out of interest I also tried to change the Max SOC to 885% (from some advice on the thread) and itches up with a "write failed" message. Any idea what's happening? It accepted the time slot.
Thanks for all the help and time.
If you have a Global Max SOC of 100%, and try to set a lower value for charging, then it might not stick.jem wrote: ↑Thu Apr 23, 2026 8:59 am Hi, I've set up a different time slot in the work scheduler part of the app. I'wills see tomorrow if that overwrites the one that has currently been operating I set before the change. Out of interest I also tried to change the Max SOC to 885% (from some advice on the thread) and itches up with a "write failed" message. Any idea what's happening? It accepted the time slot.
It could also have been a communications glitch.
Also, the battery will be fine with 100% Max SOC, you would have to seriously abuse the battery to wear it out (very cold/very hot or leaving it at 10%/100% for long periods)
You can still use the basic scheduler from the v2 website.
From the Dashboard, go to Quick Settings on the top right. Then go to Advanced Settings again on the top right.
The basic schedule settings are in ChargingTime option.
Not seeing what you are here?brunofabre wrote: ↑Thu Apr 23, 2026 11:03 pm You can still use the basic scheduler from the v2 website.
Can you take a screenshot/video of what you are seeing?
I don't use the website, so may have missed something
Just realized it is because I have registered as an Agent which gives me installer level access.
Here is the screenshot from the Dashboard after click on Quick Settings. When I login as an End User I don't see the Advanced Settings button.
Aha!brunofabre wrote: ↑Fri Apr 24, 2026 10:19 am Just realized it is because I have registered as an Agent which gives me installer level access.
Well thanks for confirming, I thought I needed new glasses
At least we know the options exist, for Agent level accounts, so cheers for posting back.
That was for the v2 website. The v1 website can set the basic scheduler as an end user.
I noticed that the App now has the Mode Scheduler enabled again.
Hi rolotwix12
I have exactly the same issue when I try to change the Max SOC below 100%. It gives Code 44098 write fail
Anyone knows what can be done?
Thanks.
Thanks.
Happened to me when Mode Schedule was set.
In app go to Work Mode and change away from Mode Scheduler - for instance to Self Use.
Then go into quick settings and see if you can change Max Soc now.
H1 5.0 E G2 inverter
EP11 battery
3680W solar 8 panels
EP11 battery
What about if you completely delete any schedules in Mode Scheduler, then back in Self Use try quick settings MaxSOC again?
I have tried this in the past, I was able to save MAX at 90
But the MIN defaults back to 10 after a day or two
It has just worked ok for me.
Could you check if you are on latest firmware
viewtopic.php?t=1927
Other suggestion is to use the web interface
EP11 battery
EP11 battery
Daveg, my software version is 1.8.
I tried the website. I tried changing the 100% but it keeps saying fail write. Has anyone tried writing to the manufacturer?
Sorry, I'm no expert in these things, just a user who's encountered the same issue of adjusting MaxSoc that you've got and so am going through the things I've done to get round it over the past 10 months.
One was to disable/delete all schedules and go into self use mode, the other was to apply a firmware update that was offered on the app.
I should say though that I've applied two firmware updates one of which broke scheduling, so I'm not personally in a position to fully recommend that route even if available.
Hopefully someone more knowledgeable can help.
I'll just add that I've also been advised here that reducing MaxSoc below 100 has downsides in terms of the battery management system - but that's not an excuse for it not working.
EP11 battery
EP11 battery
I understand the recommendation is to let the battery reach 100% once a quarter.
I've been trying to follow the recommendations from here
viewtopic.php?t=3121
EP11 battery
EP11 battery
I've been trying to remember what I had to do to get round this problem the first time it happened. I think this was the sequence:
1. login on version 1 of the web interface
https://www.foxesscloud.com/login
2. In the left hand column choose Device - Inverter
3. In the Inverter screen that appears click the far right hand side column 'Operation' - looks like a word document icon
4. In the inverter details screen that will appear choose 'Work Model:Self-Use' and click the edit icon next to it.
5. In the work model screen that appears click disable against strategy period and also delete every strategy period you see - click minus sign at right hand side. Then click Save.
6. Go to the app (or v2 web interface https://www.foxesscloud.com/v2/login ) and try to change MaxSoc
This was all before v2 web interface, v2 app and various firmware updates existed of course, but if nothing else is working you might think it worth a try.
Edited step 5 changed LHS to RHS
EP11 battery
EP11 battery
Deleted - point made had no relevance to thread title.
EP11 battery
EP11 battery
