Re: Option to schedule charging disappeared
Yes, I get it. Thanks.
So I use Mode scheduler now instead? I can not see anywhere my current off peak charging though that was expecting to see (and disable). My battery currently charges at 3am for one hour and I want to stop this.
jem wrote: Wed Apr 22, 2026 6:42 pm Yes, I get it. Thanks.
Try the V1 Website, hopefully it still exists in there.
https://www.foxesscloud.com/login
I'm in the UK, on the Fox cloud 2 app we can click on the "work mode" icon to call up " mode scheduler"
On this mode we can enter
Self use
Feed in priority
Back up
Forced Charge
Forced Discharge
So you can charge for various times, discharge when you want by putting in what time settings you need.
Can you download the Europe issue of the App, could this help?
I had the same problem when he app changed last month.
I have the off peak times set up for battery charging and just toggled it on or off when i needed to. That function disappeared from he app so the workaround was to use the desktop version (which briefly worked), but now I can not see the time slot I had set up now in the desktop (but is still charging in off peak), I now want toggle off.
This is all I've used the app for, or probably ever will, its over complicated for me and now doesn't seem to do what I want (or maybe it does but its buried in all the other functions).
Hi, I've set up a different time slot in the work scheduler part of the app. I'wills see tomorrow if that overwrites the one that has currently been operating I set before the change. Out of interest I also tried to change the Max SOC to 885% (from some advice on the thread) and itches up with a "write failed" message. Any idea what's happening? It accepted the time slot.
Thanks for all the help and time.
jem wrote: Thu Apr 23, 2026 8:59 am Hi, I've set up a different time slot in the work scheduler part of the app. I'wills see tomorrow if that overwrites the one that has currently been operating I set before the change. Out of interest I also tried to change the Max SOC to 885% (from some advice on the thread) and itches up with a "write failed" message. Any idea what's happening? It accepted the time slot.
If you have a Global Max SOC of 100%, and try to set a lower value for charging, then it might not stick.
It could also have been a communications glitch.
Also, the battery will be fine with 100% Max SOC, you would have to seriously abuse the battery to wear it out (very cold/very hot or leaving it at 10%/100% for long periods)
Global Max? Where is that please? Thanks
jem wrote: Thu Apr 23, 2026 2:30 pm Global Max? Where is that please? Thanks
Your earlier post, the Quick Settings, website v2 site
viewtopic.php?p=16134#p16134
