Upgraded Datalogger firmware to 1.09 and lost 5s updates
I'm at a bit of a loss. I noticed in the Cloud 2.0 app that I could update the W6 datalogger firmware to v1.09 from v1.08. I had 5s updates working in v1.08 (this firmware on a new install). Pressed update, waited, all went well. No errors. Everything back online.
The issue is, I seem to be on 5 minute updates now.
Has anybody bumped into this before, and do you have a fix?
The documentation says that for 5s updates the firmware needs to be v1.08 or greater.
Re: Upgraded Datalogger firmware to 1.09 and lost 5s updates
A discussion here yesterday: viewtopic.php?p=15050#p15050
The short answer was the 5s refresh took a bit of time to "recover" for me it worked, then stopped working, and recovered a few hours later.
Thanks.
9 hours later it seems to be back.
Good to hear, must take some time to settle (no idea why though)
I also encountered the same issue after upgrading my datalogger from firmware v1.08 to v1.09 this morning. Now my 5-second refresh bubble icon has disappeared and it only updates every 5 minutes. I hope after 9 to 12 hours this feature will come back and work as other users reported.
I also encountered another issue after the firmware update: my battery showed as offline. Luckily, Gemini instructed me to power off the inverter and battery and turn them back on again; this resolved the battery offline issue.
Confirming 9 hours later, my 5-second update works as well. I could pinpoint that 9-hour window—it’s definitely a "hidden" rule of the new v1.09 security handshake that Fox ESS doesn't mention in the update.
I also have the W6 Datalogger and upgraded to the 1.09 firmware, also lost the 5 second updates and now only getting 5 minute updates. It’s been 3 days now and still can’t get the 5 second updates back.
I’ve restarted my inverter and my Datalogger and nothing…!
I logged a support call with Fox 3 days ago and they haven’t even bothered to respond so that says a lot about their support….wondering now if Fox was a good decision…?
kevinbg007 wrote: ↑Fri Apr 03, 2026 9:35 pm I also have the W6 Datalogger and upgraded to the 1.09 firmware, also lost the 5 second updates and now only getting 5 minute updates. It’s been 3 days now and still can’t get the 5 second updates back.
It's either unplug/replug in the datalogger.
Or go through the process to add your WiFi credentials again, it might just wake it up.
Gemini instructed me to reset my dongle password and wait for 9 hours; the 5-second refresh fixed it on v1.09.
"Reset the Dongle Password:
​Access your Fox ESS dongle settings (usually via the local Wi-Fi configuration page or the FoxCloud app).
​Reset or re-enter your Wi-Fi/Dongle password. This often forces a handshake refresh with the Fox ESS servers."
I’ve unplugged the Datalogger waited 60 seconds and plugged it back in, still not getting 5 second readings.
I’ve reset the WiFi and even put it onto a different WiFi network, waited over 9 hours, still not getting 5second readings back.
Today I’m going to shut my KH10 inverter down and restart it - fingers crossed but not hopeful.
Still no response from Fox support :-(
Failing that I’m going to try and go back to v1.08.
kevinbg007 wrote: ↑Sat Apr 04, 2026 10:17 pm I’ve unplugged the Datalogger waited 60 seconds and plugged it back in, still not getting 5 second readings.
Maybe try changing your Foxcloud password as well to see if that will sync with the server.
I restarted everything and that didn’t work so have now changed my password as suggested. I’ll see later tonight if that works or not.
Nb still no response from fox support.
UPDATE:
Still nothing and stuck on 5-minute updates... Tried everything and still no response from Fox Support.
Now going to find a way to downgrade back to v 1.08 firmware.
kevinbg007 wrote: ↑Tue Apr 07, 2026 11:43 pm UPDATE:
I have the same issue after upgrading my datalogger from v1.08 to v1.09, and here are the steps I took that fixed my 5-second refresh issue.
The Resolution Steps:
​Local Inverter Access: Log in to the datalogger via a web browser (like Chrome) using its local IP address (192.168.xx.xx).
​Authentication: Use the default credentials for the v1.09 dongle:
​Username: admin
​Password: 12345678
​Credential Update & Reboot: Change the login password from the default and immediately click the Restart icon on the interface.
​App Refresh: Clear the cache and data for the FoxCloud app on your phone. This forces a fresh login and clears any stale session data.
​The Waiting Period: After completing these steps, the 5-second updates didn't appear instantly; it took approximately 9 hours for the system to stabilize and for the real-time data to consistently reflect in the cloud.
I'm not sure why it doesn't resolve your issue, sorry.
Thanks for all the advice, I've tried all these things and still nothing (stuck on 5-minute updates). :( :( :( :( :(
Today I'm going to find the v1.08 firmware and load it back into my datalogger as it now seems to be the only fix. FoxESS support have not helped at all so I believe there is an issue with my combination of equipment and this v1.09 firmware they can't resolve.
I have KH10 Inverter, W6 Wi-Fi Datalogger, and CQ6 Batteries. All working perfectly before V1.09 Datalogger firmware upgrade.
I can't find the v1.08 firmware anywhere online and Fox Support don't respond and don't even answer their phone - Looks like I'm screwed....
I'm at the stage now where I'm looking at posting this onto Social Media so people can make their own minds up about whether they want to install FoxESS equipment, plenty of other choices out there - right.
kevinbg007 wrote: ↑Wed Apr 08, 2026 10:57 pm Thanks for all the advice, I've tried all these things and still nothing (stuck on 5-minute updates). :( :( :( :( :(
I have a KH10 Inverter, a W6 Wi-Fi Datalogger, and EQ4800 Batteries.
KH10 firmware version:
Master v1.60
Slave v1.02
Manager v1.58
Datalogger v1.09 refreshes every 5 seconds without any issues now.
Seems like the issue I have been facing since my system was installed couple of weeks ago. data logger is v1.08 and it has never managed to show any inverter data despite all my attempts. Something is seriously off :|
Data Logger W6: v1.08
Kh10 inverter
Well finally got a response from Fox support by lodging a ticket via the App contact section. Owen at support managed to downgrade my W6 datalogger back to V1.08 and after I did a hard stop/restart of the inverter and datalogger, I'm now back to 5 second updates in the App. (Thanks Owen)
Question is why did V1.09 fail and what is Fox going to do to resolve this as I am reluctant to upgrade it again any time soon.
kevinbg007 wrote: ↑Thu Apr 16, 2026 11:49 pm Question is why did V1.09 fail and what is Fox going to do to resolve this as I am reluctant to upgrade it again any time soon.
It's only failed for some, there's no rhyme nor reason to it.
For some 1.09 took two attempts to load, and if you loaded it again, it might actually work. (I wouldn't recommend you load it)
Best thing you can do, is just skip past 1.09, wait for 1.10 or higher, and for some fool (like me!) to load it first.
not sure if they have sorted this but my data logger is on v2.04 and seems to be working properly ...with 5 sec updates
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
v1.10 is ready to update. Has anyone tried it yet?
luuniem wrote: ↑Thu May 14, 2026 11:01 am v1.10 is ready to update. Has anyone tried it yet?
Yes, did it without a thought in my head :lol:
viewtopic.php?p=16635#p16635
